How to use current Layout ID and name i GDL script
I'm trying to create a GDL object for making revision handling easier. This objects needs to "know" which layout it is placed on (the Layout ID and name).
I know I can use the <LayoutID> to create an autotext in the object, but that is not what i'm after, because I want to be able to store the Layout ID and Layout name in a database.
Is this possible, and how do I do it, or where can I read about it? I have looked through the GDL reference guide but I can't find anything.
7 REPLIES 7
It is not possible.
You can use autotext in an object but you can never retrieve the value of the autotext itself.
So you can't pass its value onto a parameter or to a database.
Thanks for a fast reply.
It's a shame it can't be done.... That means I can only generate lists of layouts based on the built in scheme tools.
The problem is that the layouts have to few parameters. I would be great if they would have a lot of custom parameters that could be used as filters in the schemes. Then one could give the layouts parameters like "part of revision 1", and then generate a list of all layouts in revision 1 etc.
Barry wrote:
It is not possible.
I guess it's not possible then to reach the layout's ID in any other way either?
Not that I am aware of.
sinceV6
Didn't try it myself, but can't this be used?
n = request ("HomeDB_info", "", n, LayoutNumber, LayoutName, n)
http://www.graphisoft.com/ftp/techsupport/documentation/developer_docs/BasicLibraryDoc/15/DrawingTit...
and page 312 of the GDL documentation.
That above code works well. Thanks! I was trying to solve the very same problem.
sinceV6
So it works eh? YAY! Good to know for the next object/title.
