‎2021-01-20
03:24 AM
‎2023-05-24
12:24 PM
Rubia Torres
Solved! Go to Solution.
‎2021-01-26 09:20 AM
‎2021-01-20 08:35 AM
‎2021-01-20 09:10 AM
‎2021-01-20 09:29 AM
@Kristian That Infinite Openings tool looks interesting! Is there a way to easily assign custom window profiles for each frame with it?Yes the frame profiles are editable polygons which you can then store in the tools internal catalogue to apply at will. I will post in the advertising section for any more questions to avoid hijacking this thread.
‎2021-01-21 02:07 AM
furtonb wrote:This worked well! Got it perfectly. Took some time. But all is well.
Another solution could be a combination of a curtain wall + empty opening. Or you could draw it on a floor plan and save a custom window - or script it from scratch in GDL. These solutions would probably require cleaning up the 2D symbol too. I would choose depending on the project phase and required level of detail, if the house won't be subject to much change, then would I choose any of these - otherwise Kristian's solution could be faster and cheaper.
‎2021-01-21 07:59 AM
‎2021-01-25 02:19 AM
TArkh wrote:
However, the new curtain wall which I reclassified as a window, is not visible in the windows schedule, please see attached.
‎2021-01-25 09:04 PM
‎2021-02-23 11:19 PM
