I'm looking for a window
I need a window like the one in the picture, but that aligns with
the face of the wall. Or where I can find the specs for it in the windows
library.
Thank you.
Is this window unit a fixed glazed unit at the bottom with louvers above or are those internal blinds in a full glazed unit? If it is a unit with louvers you can make this window in CadImage's Door & Window Builder add-on. I don't know if you could do it with the standard library.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
It's a object that I got from archiradar and the window is with internal roll down blinds. My problem is that I don't want the "niche" that the object creates, and I could not find a simple window with internal blinds.
Ok, I found another blind object. It worked fine.
I don't know the language but it works.
Thank you.
