I need an odd sized door for ArchiCAD 9. SOMEONE HELP!
I NEED AN 112 3/4" x 80" SIZED DOOR. ITS A TRIPLE FRENCH WITH THE DOOR EITHER ON THE LEFT OR RIGHT, NOT THE CENTER. THE OTHER TWO DOORS ARE STATIONARY. SOMEONE PLEASE HELP ME. THANK YOU FOR YOUR TIME.
11 Replies 11
Sorry, can't help with your problem (I use Door and Window Builder for doors, and, er, windows, and you can have almost any door / window combination you can think of). Just wondered what DRERINGS were?
Aussie John
You may have to model it in plan and save as a door object
Cheers John
[/size]
David Pacifico
Have you tried the ganging feature?
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
I am using ArchiCAD 9 and i dont have that option. Plus it is an exterior door. I appreciate everones help on this matter.
The ganging option is available in the SE9 Library. In the normal 9 library, it's called 'Stacked Door' and can be found about halfway down the parameters list.
I LOOKED IN ARCHICADS STANDARD LIBRARY AND I DONT HAVE AN OPTION FOR A STACKED DOOR. ????? THANKS
Really? Maybe the US standard library is different. Which particular door are you using? I've had a quick look and all the doors in the INTL 9 library have the stacked door option.
IT WOULD HAVE TO BE DIFFERENT. THATS WIERD! COULD YOU POST ONE OF YOUR DOORS AND ILL SEE IF I CAN LOAD IT.
HERE IS WHAT MINE LOOKS LIKE
