ID manager in 15 lists backwards
Can anyone else please confirm or deny this problem I seem to be having.
Window 7 64 bit
Achicad 15 - AUS build 3602
ID manager lists the door IDs in reverse order.
In the example attached I selected the doors from left to right but ID manager lists them from right to left.
No matter which order I select them it does the opposite.
The odd thing is it was working fine on another machine with build 3006.
I upgraded that to build 3602 and now that is back to front as well.
So I am assuming the hotfix broke it.
10 REPLIES 10
Stress Co_
Hi Eric:
Thanks so much for posting that clip. It solved my issue.
I did one thing different.
That was to add "Element ID" from the Available Criteria to the Selected Criteria.
Works perfectly when I omit that step.
BTW...
I still get the bug I mentioned in the EDIT to my previous post.
Marc Corney, Architect
Red Canoe Architecture, P. A.
