ā2011-03-02 07:25 PM
It assumes that a folder named āArchiCAD Data Folderā exists beside ArchiCAD for user defined files. (The name of this folder is defined in the Add-On resource fork, therefore it can be localized.) If a folder with that name doesn't exist, the Add-On will create one.It doesn't seem to be creating the folder. Some things are not working as expected, so I don't know whether this file is still required. I'm not sure where "beside ArchiCAD" is: The folder? the executable?
ā2011-03-03 02:19 AM
ā2011-03-03 05:45 AM
