Imported Object is Too Triangulated for 2D Views
I have a chair object that was supplied by the manufacture as a 3D.DWG file. I have imported this object into Archicad where it renders very well. However the 2D views are too triangulated to be of any use. I know I can edit the object and insert a 2D drawing into the 2D Symbol location, but this does not help me for elevation views. I thought I could use PROJECT2 3,270,2 to clean some of this up, but the object is apparently too complex to do the "on the fly calculations" that I assume the PROJECT command performs. I am not sure the PROJECT2 command would take care of this issue anyway. Is there any way to get this object to remove the triangulations in the 2D views? I can email you the gsm object. It was too large to attach to this topic.
Erika Epstein
Sounds like a really lumpy chair 🙂
Have you looked through the GDL depository on the front page of actalk to see if there is something close to what you want?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
