Importing/Creating an object from a 3D DWG file
I can't figure this out, and I have already followed the Graphisoft Help section.
I am trying to import this 3D dwg file of a lounge chair, but I just can't seem to do it.
http://www.zenithinteriors.com/au/downloads/file/products/530/3d-cad/3000%203D.zip
Any help would be appreciated. Like I said I have followed the Graphisoft help topic already but I just can't get it to work so maybe I am just doing one simple thing wrong with my settings... not sure.
thanks
5 Replies 5
David Maudlin
robmeneses:
This is what worked here:
1. Open Object..., Open Library Part > Browse for a Folder, navigate to one of the .DWG files, select the file.
2. Set the Translator to 02 For editable import, click the Settings... button, and in the DXF-DWG Translation Setup > Settings > Open Options > 3D data in created Library Parts: GDL Script and check both Enable partial open and Convert 3D Solids, Regions and Bodies into GDL objects, click Save Settings & Close.
3. Click Open.
4. In the DWG/DFX Partial Open dialog box, all layers are visible, click OK.
5. The DWG file opens as a library part, check the 3D View, it should be visible.
6. Save As... the library part into a folder that is loaded via the Library Manager into the project that will use this library part.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
That's brilliant David - it worked.
Very much appreciated!!!
David Maudlin
Rob:
Thanks for posting that worked (and for adding the signature). Additionally, once you have the Object, you can convert it to a Morph for editing (removing lines, etc.) then resave it as an Object.
Hey David, I just tried the whole "change object into morph" tip to amend specific details and it's brilliant!
That's exactly what I was looking for as I needed to make some 'surface' changes to the objects that I had downloaded.
Massive thanks for the extra tip.
David Maudlin
Rob:
Yes, I have found dwg type objects less than perfect, so this allows modification without GDL knowledge.
