Importing/Creating an object from a 3D DWG file
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-12-03 09:44 PM
‎2015-12-03
09:44 PM
I am trying to import this 3D dwg file of a lounge chair, but I just can't seem to do it.
Any help would be appreciated. Like I said I have followed the Graphisoft help topic already but I just can't get it to work so maybe I am just doing one simple thing wrong with my settings... not sure.
thanks
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-12-04 02:59 PM
‎2015-12-04
02:59 PM
robmeneses:
This is what worked here:
1. Open Object..., Open Library Part > Browse for a Folder, navigate to one of the .DWG files, select the file.
2. Set the Translator to 02 For editable import, click the Settings... button, and in the DXF-DWG Translation Setup > Settings > Open Options > 3D data in created Library Parts: GDL Script and check both Enable partial open and Convert 3D Solids, Regions and Bodies into GDL objects, click Save Settings & Close.
3. Click Open.
4. In the DWG/DFX Partial Open dialog box, all layers are visible, click OK.
5. The DWG file opens as a library part, check the 3D View, it should be visible.
6. Save As... the library part into a folder that is loaded via the Library Manager into the project that will use this library part.
3. Click Open.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-12-04 09:35 PM
‎2015-12-04
09:35 PM
That's brilliant David - it worked.
Very much appreciated!!!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-12-05 02:59 PM
‎2015-12-05
02:59 PM
Rob:
Thanks for posting that worked (and for adding the signature). Additionally, once you have the Object, you can convert it to a Morph for editing (removing lines, etc.) then resave it as an Object.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-12-08 08:31 AM
‎2015-12-08
08:31 AM
Hey David, I just tried the whole "change object into morph" tip to amend specific details and it's brilliant!
That's exactly what I was looking for as I needed to make some 'surface' changes to the objects that I had downloaded.
Massive thanks for the extra tip.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-12-08 02:18 PM
‎2015-12-08
02:18 PM
Rob:
Yes, I have found dwg type objects less than perfect, so this allows modification without GDL knowledge.
