Instant GDL
I've learned that dragging a 2d selection to the 2d script window and a 3d selection to the 3d script window, archicad codes the gdl automagically! My issue is, with the same object the 3d part of the object is always offset from the 2D part. (I'm using a converted 3ds file as a base for this object - a hoven from gaggenau - and I did myself the 2D part!) Is there anything that I can do so that the 3d and the 2d part coincide?
You can temporarily insert the line:
Project2 3, 270, 2
At the beginning of the 2D script. This will draw a projection of the 3D model into the 2D view and allow you to check the offset. You can then adjust the drawn symbol or 2D script accordingly.
Thanks! Will try that
