ā2004-08-02
05:46 PM
ā2023-05-26
11:46 AM
Rubia Torres
ā2004-08-02 08:21 PM
dukaos wrote:You should first select the walls or the zone in the room that you want the interior wizard to work on.
I am trying to create an interior that includes base, chair and crown molding, but I can't get the Int. Wizard to work.
ā2004-08-02 08:46 PM
ā2004-08-03 12:57 AM
ā2004-08-03 01:47 AM
dukaos wrote:For the Interior Wizard, you select a zone first. Then Interior Wizard and go through the steps. You do NOT click again anywhere on the plan with the interior wizard selected. The moldings/etc will be applied to the walls that are touched by your zone.
Yes, I have selected the wall, but the moldings I've designed do not adapt to the wall. I click on the wall to select it and when I click again with the Int Wizard selected, I only get the option pop-up that lets me alter the wall. It sounds like I am missing a step, yes? Shouldn't my wall with the moldings become one with the wall I selected?
ā2004-08-03 02:00 AM
