Interface page navigation
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2015-11-11
02:43 AM
2023-05-24
10:05 AM
Rubia Torres
2015-11-11
02:43 AM
(I've tried to figure out how Graphisoft do it, but have gotten completely lost amongst all their macro calls.)
If I set the UI_CURRENT_PAGE via the drop down selection, the UI_PREV and UI_NEXT don't work, and vice versa.
Any hints?
Thanks
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Mindmeister Mindmap
-- since v8.1 --
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-11-11 05:47 AM
2015-11-11
05:47 AM
If I understand correctly, here's a simple example with reference to the standard macro = "ui_tabcontrol"
You create a parameter = "gs_ui_current_page"
tabTitles - You can also create a parameter or make the array directly in the script interface.
!!!PARAMETERS SCRIPT !!! You must create the parameter named=gs_ui_current_page VALUES "gs_ui_current_page" 1,2,3 IF GLOB_UI_BUTTON_ID > 2 and GLOB_UI_BUTTON_ID < 2.1 THEN PARAMETERS gs_ui_current_page = GLOB_UI_BUTTON_ID - 2 ENDIF !!! INTERFACE SCRIPT UI_DIALOG "SL-GDL" ! Your any text UI_CURRENT_PAGE gs_ui_current_page UI_PAGE gs_ui_current_page DIM tabTitles[3] tabTitles[1] = " Parameters" tabTitles[2] = " Represent" tabTitles[3] = " Info" UI_BUTTON ui_prev, "<<", 295+10,2, 32,21, gs_ui_current_page - 1 !!!! Previous UI_BUTTON ui_next, ">>", 295+10+33,2, 32,21, gs_ui_current_page + 1 !!! Next page !!! HEAD !!! Example without icons CALL "ui_tabcontrol" parameters controlType = 1, nTabs = 3, gs_ui_current_page = gs_ui_current_page, tabTitles = tabTitles, drawBox = 1 !!! PAGES UI_PAGE 1 UI_PAGE 2 UI_PAGE 3
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-11-11 09:51 AM
2015-11-11
09:51 AM
Her is a sample for handling ui pages: http://gdl.graphisoft.com/tips-and-tricks/how-to-set-up-tabpage-controlling-in-ui/
_________________
Gergely Fehér
Team Leader, Library Team
GRAPHISOFT SE
Gergely Fehér
GRAPHISOFT SE
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-11-11 11:32 AM
2015-11-11
11:32 AM
Standard macros is a good thing, but there is always the danger that in a new release of version of the GS change the script (or remove some parameters) so that the element will stop working. Well if this is a basic macro that you give a link CALL "...", but if it happens in other levels? Eg. windows - doors, a large number of macros. Modern elements are so complex and they have a CALL "..." a few times (possibly in a circle inside).
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-11-11 09:48 PM
2015-11-11
09:48 PM
Thanks guys - a great help. Don't understand it yet, but I'll get there. Ta
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Mindmeister Mindmap
-- since v8.1 --
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-11-14 03:04 AM
2015-11-14
03:04 AM
Got it working. Turns out the key was adding the "gs_ui_current_page - / + 1" in the UI_BUTTON command.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Mindmeister Mindmap
-- since v8.1 --
