‎2007-11-12
08:50 AM
‎2023-05-26
12:22 PM
Rubia Torres
‎2007-11-12 09:10 AM
moloneyds wrote:It's still one of only two ways I can see of doing what you want if you want the walls cropped to a different extent than the text/dimensions.
Hi All,
Can I ask what method people use for internal layouts. I learnt a method back on version 7 from Barry, but I feel that may be a bit out-dated. Then again it could be the best method.
The method I'm using in the layout book is using 2 drawing windows.
The first window contains all the walls, doors, cabinetwork etc. The second just has the text.
The first window is manipulated in the layout book so the walls are cut away to just show the walls relevant to the layout. The second window is overlayed and lined up using a hotspot. The out come is show attached.
I'm open to a new method, if it is more efficient.
Any input is greatly appreciated.
