Pato99
Lamps in the Grasshopper Connection
Hi, I've been systematically converting our template to make use of Grasshopper, to speed up the drawing process. Since we do 400ish custom homes per year, cutting out a lot of the grunt work will make a huge difference.
I just noticed as I'm beginning to adapt electrical layouts (which we have a set number per zone type) there's no option for Lamps. Why is that? Did I miss something?
My use case would be filling a room with LED downlights, using Deconstruct Zone, Areas/centroids/boundaries and offsets.
Surely big commercial projects use this? or make fancy parametric lighting facades with schedulable Lamps? No?
I also noticed the newer "Equipment" category is missing also, when can we expect to see these items added, there is nothing on the roadmap?
Versions 10 to forced subscription
Please vote for Constant thickness to mesh What will GS do when they reach 200 votes? Less than 30 votes to go!
Please also vote for my whishes, as 200 votes in 6 months is an impossible target, don't be a bystander:
1. Relative file locations | 2. Auto text in Publishing | 3. Model types to Grasshopper | 4. Index Numbers in Search | 5. Step through Elevations | 6. Rhino is better than ArchiCAD
Here's a reminder of what you're voting for: Wishes Delivered
0 Replies 0
