JP
molumba
Archicad 26 (7004) crashes after connecting to Rhino 7
Hi,  I need to model some complex geometry in grasshopper to feed into our AC26 (7004 INT FULL) project.
When i connect the two softwares using grasshopper, Archicad crashes and  closes.  In grasshopper the sync is successful.
I have tried both the Live Connection installers from Graphisoft  that were supposed to work for Archicad 26 (win) and they both crash.
Grasshopper-Archicad_Connection-26-INT-4023-1.1
Rhino Version 7 SR30
(7.30.23163.13001, 2023-06-12)
What could be the solution?
Operating system used: Windows 7004 INT FULL
Setup info provided by author
Nurbs
Hi molumba,
It could be that the connection crashes due to the complexity of your Rhino geometry. Have you tried the connection with a simple geometry first?
A second test would be to import the Rhino file into Archicad without using Grasshopper and see what happens then.
AC16 - AC29, Rhino 5-8. Alienware WIN 11
