‎2004-03-22
11:24 PM
‎2023-05-24
12:50 PM
Rubia Torres
‎2004-04-06 12:02 AM
tsturm wrote:ah, so you read the manual when you first got it then?
Ben had stated in one of his posted that the volumes were "share points". So it took me some time to figure out how to configure the XServe to change the sharing properties of the contents so that I could then access these "share points". This all had to be done from within the Workgroup Manager application which comes with the XServe. Once I had made the "share points", like making a folder as a shared volume under OS 9 instead of the entire hard drive.
Matthew wrote:i would go as far as saying the their was no real problem - just an incorrect configuration. that's not to say that there
Just for the record, the issue is not with XServe (the hardware) but with OS X Server (the software).
‎2004-04-06 04:40 AM
~/archiben wrote:That's why I diplomatically referred to it as an "issue"Matthew wrote:i would go as far as saying the their was no real problem - just an incorrect configuration. that's not to say that there
Just for the record, the issue is not with XServe (the hardware) but with OS X Server (the software).aren'tany quirks in apple's filesharing protocol . .
[matthew - soPartly... I guess it's more recognizable than you are in hat and gogglesthat'swhat you look like?! ]
~/archiben
‎2004-04-06 10:53 AM
Matthew wrote:yeah - i do also recall seeing the full colour version in nottingham last year. . .
Did you catch the color version earlier today?
‎2004-04-07 12:36 AM
‎2004-04-07 07:04 PM
Aussie wrote:john
That said you can get problems which I havent been able to resolve where an file created by a user often sets the permissions so only the user has access ( ie the group is set to read only).
Setting permissions seems to be an artform I have yet to conquer.
‎2004-04-08 12:08 AM
‎2004-04-12 11:35 PM
‎2004-04-13 12:13 AM
‎2004-04-13 12:31 AM
tsturm wrote:any chance you've been using the same file on a PC . . . or that the library you're working on has been loaded/opened/browsed by a PC?
Everytime I go to the Library Manager it seems there is some folder which will not open up to let me see the contents.
This started out on the folder which I was working out Locally from. I moved all the contents to another folder and deleted the old one. Things seemed good until I went to load the LOCAL ArchiCAD library. I am not able to open this directory.
tsturm wrote:try moving the
What is going on???????
‎2004-04-13 03:20 PM
