2014-06-11
08:40 AM
2023-05-26
11:16 AM
Rubia Torres
2014-06-11 11:14 AM
2014-06-11 03:13 PM
2014-06-11 11:52 PM
2014-06-12 01:06 AM
Jonathan wrote:The ID field should be (if not make it) visible in your Info Box... so that you can assign/edit the ID for each window/door as you select it.
I had to custom text the numbers and letters sequentially for both doors and windows to get a diff. id for each opening. Also, didn't see any other way to get them numbered and lettered in a logical way. I like to start at the front door and follow a clockwise direction around the building.
2014-06-12 05:00 AM
Karl wrote:A bit dated, but this may help:Jonathan wrote:If you need to renumber/reletter your windows/doors in one go, that is what the Element ID Manager is for. Lots of topics discussing what you're doing and the EIM.
2014-06-12 06:48 AM
2014-06-12 07:26 AM
2014-06-12 07:49 AM
Stress wrote:
What info do you want in your schedule?
Start with the "window schedule" included in the standard AC17-residential template and edit it to your needs.
2014-06-12 04:00 PM
Jonathan wrote:This is probably due to the Criteria panel in the Scheme Settings, take a look at it, post a screen shot.
I'm trying to create a door schedule and the schedule is not populating.
I numbered the doors with the element ID manager, but when I open the schedule it has no doors in it?
