dwyckoff
Keynote Indicator_NCS 27 Not Showing on Sheets
As seen in viewAs seen in viewAs seen on the sheetAs seen on the sheet
I am having issue with the Keynote library part in V27. It shows fine on the view, but once that view is placed on a sheet it along with the arrow disappear. Layer is on in the combination, and phase is set correctly but only these items on the layer are missing on the sheet. I have exhausted every option and nothing changes. Any suggestions welcomed.
DWyckoff
Master of Time and Space
Whenever the wife lets me
A/C27, OSX12.7.5
1 Solution
Guru
You have forced a rebuild, and I assume since then that you have reopened the project? Tried re-placing the View? The Pens in the two images are different, so something is not showing what it should be...
Ling.
Go to post
4 Replies 4
Guru
So when you open the Source View from the Layout, they show?
dwyckoff
Correct. The two images show the source view and the layout.
DWyckoff
A/C27, OSX12.7.5
Guru
Ling.
dwyckoff
It was a combination of pens and graphic overrides. I have not used AC for about 8 years and the template I have is also about that old. Thanks for the whack upside the head.
DWyckoff
A/C27, OSX12.7.5
