We value your input!
Kitchen cabinets - editing heights and static knobs?
nhross
Recently, I have noticed that it has been impossible to change the height of the base cabinet 25 via the 'info box', and instead this must be done in the 'object selection settings'. Any ideas before I go down a rabbit hole of playing 'trial and error'
Also, future edits on cabinet sizes seem to muck up knobs on cabinets, either in the horizontal;, vertical, or both...
Thank so much!!
PS - running AC25 on MacOS Big Sur
1 REPLY 1
Jerryjb
I agree there is an issue here that needs addressed.
Is there a way to get the knobs reference from the opening corner rather than some random offset.  This is probably a gdl scripting needed to change in the original objects.  It makes no sense to have the offset dimension the way it is.  Every time the cabinet changes size you have to go through a whole process to get the knobs in the right spot.  Definitely needs fixed.
Base cabinets should reference top operable corner.  Upper cabinets should reference the bottom operable corner.
