‎2013-05-30
04:23 AM
‎2023-05-24
10:52 AM
Rubia Torres
‎2013-05-30 05:15 AM
‎2013-05-30 08:54 AM
Oddly enough the file in the version 16 AUS library is called "LibraryGlobals13" and not "LibraryGlobals16"I assume the part name is because the feature was introduced with AC13.
‎2013-05-30 05:37 PM
‎2013-05-31 09:35 AM
Barry wrote:From my experience it is not necessary, to use the keyword "LibraryGlobals" in the name.
It is a bit like the "Master_GDL" macros - you can have as many as you need so long as they are saved with the key words "LibraryGlobals" in the name.
‎2013-05-31 09:42 AM
Joachim wrote:Correct.
You have to choose the subtype "Library Global Settings" and name it whatever you like; the object should not been placeable as well.
