Label Global Position
JaseBee
Anyone know of a GDL command to call up a labels global position?
Looking go something akin to 'GLOB_WORLD_ORIGO_OFFSET_X' or 'SYMB_POS_X' but for labels.
Need it for an unlinked labels position in an elevation, I have created a story marker label for linking to slabs in elevation/section, but i'd like to create an unlinked one that just reads its position in the world. (Could easily do it with an actual object but I would like to use the label part if possible to avoid confusion.)
Thanks, Jase.
AC 24 5004 AUS
iMac OSX (10.13.6) 4.2ghz i7
8gb ram/8gb vram
1 REPLY 1
JaseBee
Just realised the information I needed was right under my nose, LABEL_POSITION parameter has all the global origin data in its return array.
Bit of a brain fart moment back there, not sure why I didn't check that out... whoops.
AC 24 5004 AUS
8gb ram/8gb vram
