Label Moving when Wall Angle changes
JGoode
I am having an issue with a label that I have created.
It doesn't seem to 'stick' to where I place it. When I adjust the wall angle, the label will jump around.
I'm not sure how to stop it from jumping about.
Thanks
ArchiCAD 27
Windows 10
1 REPLY 1
JGoode
So it turns out that the label isn't getting placed exactly where it should be. It is being placed where the base of an arrow would be if it was enabled.
ArchiCAD 27
Windows 10
