2010-08-21 05:22 AM
2010-08-23 08:11 AM
2010-08-23 06:59 PM
2010-08-24 08:47 AM
!################################################################################ ! ! Etikett-Parameter-Routine von Frank-Beister+ Jochen Sühlo DIM NP[],valS[],valN[],valA[],valAt[],askP[13],valP[],sts[],stsT[] !### request all parameters from main object and !### store name and value into the arrays i=1 do NameP="" rrr=REQUEST ("ASSOCLP_PARVALUE", i, NameP, Art, Zustand, Dimension_1, Dimension_2, Wert) if rrr then NP=NameP : valS="" : valN=0 : valA=Art maxP=i if Art=4 then valS=Wert else valN=Wert endif sts=Zustand i=i+1 while i<501 and rrr !### print list DEFINE STYLE "Links" LABEL_FONT_NAME, LABEL_TEXT_SIZE,3,1 DEFINE STYLE "Rechts" LABEL_FONT_NAME, LABEL_TEXT_SIZE,1,0 s=-LABEL_TEXT_SIZE/1000*GLOB_SCALE*1.5 for i=1 to maxP STYLE "Links" f=f+1 : text2 0,0,NP STYLE "Rechts" IF valS="" THEN txt=str("%.4",valN) ELSE txt="»"+valS+"«" text2 t,0, txt + " (type=" + str(valA,1,0) + " · " + str(sts,1,0)+"?" ADD2 0,s NEXT i
2010-08-24 03:54 PM
2010-08-24 04:39 PM
2010-08-25 03:52 AM
2010-08-25 08:16 AM
2010-08-25 09:40 PM
