Find the perfect object, manage libraries, create custom objects
Labels: how to show a roof angle in percentage?
I want to create a roof label that shows the angle of the roof on a percentage base. I assume that the GDL string expression only shows the value of the angle as a gradi, as in the following expression: [STR(ROOF_ANGLE xxx)].
What is the mathematical expression for the percentage equivalent value?
3 REPLIES 3
TEXT2 0,1,STR(100*tan(ac_roofang),6,2)
OR
TEXT2 0, 0, STR ("%10.3dd",100*tan(ac_roofang) )
CU mirco
www.3dsmile.it
OR
Graziae Mirco Sorgato!
It works fine...not with ac_roofang but with Roof_Angle:
STR(100*tan(ROOF_ANGLE), 6, 2)
Congratulations for your site and associated objects. They are very good!
I am exploring the "Ponte FL (m)". A very parametric bridge! How did you scripted the main hyperbolic pillars?
Jaime Neto
Archicad 9.0; PowerBook G4, 1Ghz Ram
Hi Jaime,
ac_roofangle is a parameter name inside :
Accessories extra and
Skylight.
But you asked Roof_Angle ..... You have right!! Sorry.
Thx for the sit .
For my objects instead ..... i think they're not good but even bad.
Is'nt a really hiperbolic form
A = 50
B = 30
ZZYZX = 20
aa=1.5
bb =1
cc =.5
render = 0
num3 = 15
path= 1
FOR iii = 1 to 2
konta = 0
FOR ii = 1 to 2
Konta = 1 + konta
For i = 180 to 270
IF pippo THEN num3 = 360-360*2/180*i ELSE num3 = 15
PUT -((a*3/4-A/10)*cos(i/2)), -(b/2-aa)*sin(i), -zzyzx*sin(i), num3
IF path THEN HOTSPOT -((a*3/4-A/10)*cos(i/2)), -(b/2-aa)*sin(i) , -zzyzx*sin(i)
NEXT i
For i = 90 to 180
IF pippo THEN num3 = 360*2/180*i ELSE num3 = 15
PUT a-((a*3/4-a/10)*cos(i/2)) ,(b/2-aa)*sin(i), zzyzx*sin(i), num3
IF path THEN HOTSPOT a-((a*3/4-a/10)*cos(i/2)) , (b/2-aa)*sin(i) , zzyzx*sin(i)
NEXT i
TUBE 7,nsp/4,1+2+4+8+16+32+64*render,
0,0,2,
-cc,bb/2,2,
0,bb,2,
aa,bb,2,
aa+cc,bb/2,2,
aa,0,2,
0,0,-1,
get (nsp)
Addy B
MULy - 1
NEXT ii
DEL konta * 2
pippo = 1
ADDy B*2
NEXT iii
DEL 2
CU mirco
www.3dsmile.it
