aebayles
Lamp Objects
Where are we getting better lamp objects from? The options in the Archicad library are lacking, especially with the level of renders that clients are wanting.
2 Replies 2
Lingwisyer
Guru
Foregoing the IES, I just model lights myself... Too many different lights from multitudes of boutique designers... Have found a few that include 3D objects, but most of them are not suitable for actual use in AC due to high poly counts.
CosminF
Maybe it helps:
https://www.bimobject.com/en/search?fullText=lamps&page=1
https://bimcomponents.com/Search/light
I would also look into 3d warehouse (if you have some designer lamp in mind, the better). You can download Collada files from there which import nicely into Archicad and then convert that into a .gsm object.
https://3dwarehouse.sketchup.com/search/models?q=lamps
For a more exhaustive list you can check out: https://graphisoft.com/downloads/parametric-objects/
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
