Leaf Undercut
Is there a reason why when using the leaf undercut setting on doors that it does not reduce the actual leaf size, this can be frustrating in scheduling etc.
Issue/bug possibly?
1 REPLY 1
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello nrkeone,
If you mean the Leaf Dimensions from the "Nominal Sizes and Tolerance..." tab, then the answer is no, it is not a bug.
That value defines the nominal size of the door leaf (like a door with 1.00 m nominal width is usually 0.98-0.99 m actually). In the pictogram next to it you can even see that the size is actually measured to the very bottom of the door.
If you really need to list that value, you can use a property, and enter it manually. I know it won't refresh automatically, but it is the best option I can see for now. If you think it is common practice to list this value though, we can turn this topic into a Wish.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
