Find the perfect object, manage libraries, create custom objects
Library Part Maker - 3D Hotspots
srdavids
Hi All, I posted this a few days ago, but realized it was in the wrong subforum - Reposting here to hopefully get some better visibility and replies:
I'm new to the Library Part Maker and can't figure out how to implement or modify 3D hotspots. The couple of objects I've created, it looks like there's only a single hot spot and it's appearing about 6' above my object.
See images be low of 2 objects and their far-away hot spots:
There also doesn't seem to be any hotspots coming from the morphs used to create the object either:
Any help appreciated. Thanks
1 REPLY 1
srdavids
Well, I figured out the first part of the issue - Apparently you can only draw library parts on the 1. Main floor level of your project. I just needed to offset my modeled objects by my Main Level height to get them to align with the hot spot.
I still have not figured out how to add additional 3d hotspots
