2024-02-12 07:36 PM
Hello GDL experts. I am having a problem with a custom label I created. Among other things I need it to report the home story of the associated element. I used this basic request and passed "story_name" to a text command.
n = REQUEST("HOME_STORY", "", index, story_name)
The label reports the correct story in plan view but not in section/elevation or 3D documents. In those views it always shows the name of Story 0.
This old topic (now locked) confirms the problem, and offers a solution for openings but not for other element types. Is this considered a bug that will be fixed? Is there a good workaround? Any help is greatly appreciated, thanks.
2024-02-13 02:44 AM
I haven't tried this but is that request in the 3D script?
2024-02-13 03:54 AM
Labels don't have 3D scripts. I tried putting the request in my label's 2D script and master script with the same (bad) result.
2024-02-13 04:38 AM
Of course they don't - I should have thought of that.
I was just playing with it and I am not sure it is working in plan either.
It seems to as it is reporting the home storey of the label itself?
i.e. place object on ground floor and set to show on home and 1 storey up.
Go up a floor and label it - it shows first floor and not ground floor.
2024-02-13 04:39 AM
You could request the height from PZero then compare that to your storey heights?
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2024-02-13 05:46 AM
You are correct Barry. I was mistaken that the label was working correctly in plan view. I was fooled by the fact the active story was also the home story of the element to which the label was associated. This request seems basically useless, at least for labels, which one would assume is its primary purpose. Not sure what it's good for actually.
Lingwisyer, thank you for the suggestion. I may try that. But it will require so much more code just to do something that appears to be—and should be—simple.
So frustrating,
