David Maudlin
Library Part Parameters dialogue box
rm wrote:
Too many library part Parameter settings cannot be read because the text for the parameter setting is longer than can be viewed in the view port for the Parameters box.
For those who don't know, the right side of the dialog box can be resized. When both sides are visible, resizing the dialog box changes only the size of the left side of the dialog box. To resize the right side: click on the small arrow that is in the middle of the dialog box at the top (this closes the left side), resize the dialog box to get the width you want for the right side, then click this same arrow again to get the entire dialog box back. Now go to the Work Environment to save your Palette Scheme. I have no idea if this is covered in the manual, I found it by trial & error.
Hope this helps.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
0 Replies 0
