Library Part was not converted properly
We recently upgraded to AC16 and have since started getting two error messages when a view (elevation, section, detail, etc) regenerates. The two error messages are:
Library part was not converted properly
Cant find Macro: da_oplines_10, called at line 46 in the 3D script of file dp_storefront_panels_10.gsm.
Can someone help us track down a way to resolve these errors? Other forum posts seem related but we are having trouble applying them to our specific situation.
3 Replies 3
Jochen Suehlo
I would try to load the migration libray 10 for AC 16.
If this does not help, try to find the file "da_oplines_10" on your hard disk and load it to your library.
I think both errors have to do with the missing macro file.
Jochen Suehlo . AC12-29 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
Thank you very much Joachim! I will let you know how that goes.
David Maudlin
The ArchiCAD 10 Object Library 10 for USA is an .lcf file, so must be extracted (Extract a Container... command) to access single files or search for single files. Loading the ArchiCAD Library 10 Subset in the ArchiCAD Migration Libraries folder should be your 1st option.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
