Library object available in one drawing but not another??
Hi - I have two different projects I'm working on and in one I can locate a library object but in another the same library object does not show up.
In "Project A" I am using a library part called "W Niche 20". It is under "Object Library 20/04 Masonry 20/Wall Extras 20". There are about 14 items available in the particular folder.
Now when I open my other project "Project B" and I go to find this same "W Niche 20" object via the Object Tool it is not there in that folder. In fact in that same that folder there are only about 3 items showing up. However when I go to look for it via the Library Manager I can see it in the folder as well as the other objects that were showing up in "Project A" in that same folder.
Any idea why it is showing up my Library Manager but is not available for me to select via Object Tool? Would love to know how to solve this! Thank you!
2 Replies 2
David Maudlin
SJPHouse:
The "W Niche 20" is a Window, not an Object. It can only be used with the Window Tool.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Wow I feel silly now...somehow I got lost on the library path and thought I was seeing that as an object someplace else. Anyway just found it in the windows with no problem - still new! THANK YOU!!!
