Library objects in downloads folder
It's probably already a topic and a dumb question, but can I delete library objects downloaded from internet from the downloads folder? So they would still remain in the Archicad library?
If you copyed them in ArchiCAD Library, then YES.
David Maudlin
dirgis:
Objects that are not part of the ArchiCAD Library should not be placed in the ArchiCAD Library as they will get deleted when the ArchiCAD Library is updated or if the application needs to be reinstalled. If the objects are for just one project, put them in that project's Embedded Library, otherwise create a new folder for these extra objects and load that library in addition to the ArchiCAD Library.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
