Hi Andro and Juha again
Thanks for the replies.
Got the bounding box turned off per you suggestion, thank you.
(And added extra hotspots near the light as I'm sure you can see.)
But the wires still don't go to the light or my inner hot spots.
They still seem to go to the bounding box corner locations even though they are turned off now.
Maybe I should explain a bit.
I've just purchased Cadimage's Electrical object and it works fine for standard
AC lights (the round ones I'm showing).
However AC doesn't have several of the light symbols I want, so I'm trying to create my own.
Problem is if I can't get my lights to have wires come all the way to the light, (as the others are) it can be a confusing view, ie. (is it to that light or not?)
Don't think this is a Cadimage issue, as it works fine with AC lights but will try Monday if no solution by then.
Current script follows:
!   Name     : DimCanLight 3.gsm
!   Date     : Saturday, November 24, 2012
!   Version  : 16.00
!   Written by ArchiCAD
mul2     A/0.377748, B/0.377748
add2     0'-2.8684", 0'-2.6455"
pen     penAttribute_1
line_property       0
line2    0'-0.0000", 0'-9.7559", 0'-9.4771", 0'-9.7559"
line2    0'-9.4771", 0'-9.7559", 0'-9.4771", 0'-0.0000"
line2    0'-9.4771", 0'-0.0000", 0'-0.0000", 0'-0.0000"
line2    0'-0.0000", 0'-0.0000", 0'-0.0000", 0'-9.7559"
circle2  0'-4.5676", 0'-4.7905", 0'-4.2064"
circle2  0'-4.5676", 0'-4.7905", 0'-3.8148"
circle2  0'-4.5676", 0'-4.7905", 0'-3.4401"
line2    1'-0.0036", 0'-4.7905", 0'-8.7740", 0'-4.7905"
line2    0'-4.5676", 1'-0.2265", 0'-4.5676", 0'-8.9970"
line2    -0'-2.8684", 0'-4.7905", 0'-0.3612", 0'-4.7905"
line2    0'-4.5676", -0'-2.6455", 0'-4.5676", 0'-0.5841"
pen     penAttribute_2
hotspot2 0'-0.3612", 0'-4.7905"
hotspot2 0'-4.5676", 0'-8.9970"
hotspot2 0'-8.7740", 0'-4.7905"
hotspot2 0'-4.5676", 0'-0.5841"
hotspot2 0'-4.5676", 0'-4.7905"
hotspot2 0'-0.0000", 0'-0.0000"
hotspot2 0'-0.0000", 0'-9.7559"
hotspot2 0'-9.4771", 0'-9.7559"
hotspot2 0'-9.4771", 0'-0.0000"
define style{2}    "AC_STYLE_1" "Arial", 9'-0.3368",      0
paragraph		"AC_PRG_26"      1, 0'-0.0000", 0'-0.0000", 0'-0.0000", 3'-3.3701"
    pen     penAttribute_3
    set style "AC_STYLE_1"
        "D"
endparagraph
textblock		"AC_TEXTBLOCK_26" 0'-0.0000",      1, 0'-0.0000", 3'-3.3701", 3'-3.3701", 3'-3.3701",
        "AC_PRG_26"
richtext2		0'-2.3864", 0'-8.5857", "AC_TEXTBLOCK_26"
