Louvers in curtain wall
Hi
Any idea how I can make 2 panels in my curtain wall unit with louvers.
Should I be using the curtain wall here in the first place?
6 Replies 6
Erika Epstein
You might just try using the Vent Window 12.
If curtain wall or storefront you can make a custom panel.
Are these just louvers or louvers over glass? If the latter try windows with shutter closed.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks
Ralph Wessel
Try using the Modular Joinery object - all ArchiCAD users on subscription in the UK should all have received it, so you probably have it to hand.
You can make any arrangement of windows, doors, panels, louvres, etc. A quick example along the lines of what you requested is attached.
Ralph Wessel BArch
Central Innovation
Wow - actually I got my copy of archicad in Miami because I am doing some work overseas at the moment. Is the modular joinery object downloadable somewhere?
Ralph Wessel
No, it's only available through an ArchiCAD reseller/distributor. I would ask the company you purchased the software from. All UK subscribers get the object automatically (also the Doc M library).
Ralph Wessel BArch
Central Innovation
Cheers, I'll check with them (3DCADCO)
