MACROS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-11-28 08:04 PM
With the use of these Macros, I placed them in my drawing, related to each other (heigth,layer,etc) and then created a New Library part.
To avoid the clutter of .gsm files in this particular folder, I created a sub-folder, where I moved the Macros.
Later, when I try to place the Library Part (the one with the combined Macros) I received the messages that the Macros could not be found.
My question is: Once the Macros are combined for further use,do they have to remain in the same place? How does a CALL function in the Library Part Script, points to the location of a given Macro?
I hope this is clear enough to get some help here.
Conrado Dominguez
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-11-28 09:41 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-11-28 10:16 PM
Reloading is the answer.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-11-28 10:24 PM
As Peter notes, you must reload your libraries after moving things around.
Many macros are not intended to be placed directly. If that is the case with your macros, do note the checkbox for 'Placeable' shown in the attached screenshot. If that checkbox is cleared, your macro will not be visible to select in any of the object settings dialogs, thus reducing clutter in the user interface.
Regards,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-11-29 02:13 AM
Good to hear from you.
Now that you clarify what the "Placeable"button is, can you explain what is the otherone"Template" for?
Conrado
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-11-29 05:15 AM
Conrado wrote:'Template' lets you create your own named entries in the subtype hierarchy ... thus letting you choose your entry from the subtype hierarchy ("Select Subtype" button) which in turn would populate any new object based on your template with all of your template's parameters. This assures that a family of library parts will have all similar parameters identically specified...which simplifies work, guarantees that called 'family' macros will get parameters with the right names (no typos), and guarantees that the parts can be scheduled properly (all corresponding parameters guaranteed to have the same internal name).
Regards,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-11-29 02:35 PM
Karl wrote:In addition to Karl's list, it also assures that parameter transfer between similar library parts will work, for example, when injecting parameters from one window to another window inside the Window dialog box.
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-11-29 04:45 PM
Great question, Conrado. I never even thought to ask.
bT Square Peg
https://www.btsquarepeg.com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-11-29 08:23 PM
vistasp wrote:No, it's not. Neither in the GDL guide nor the Reference guide. It used to be there in older versions. Currently, the printed or PDF guide for 12 and 11 tells the user to refer to the online Help for "GDL Master Window". Personally, this business of not having a single, central document (Help or PDF) with
This information on macro templates is extremely interesting. It's not documented in the Reference Guide, is it?
I talked about the checkboxes three years ago here:
Attached is a screenshot of the online Help file. Lots of info there, including the color-coding scheme used for parameters in the subtype hierarchy.
The extra info on usefulness that David (thanks!) and I mention, are not included there. Nor are there screenshots or illustrations. (The older manuals at least had screenshots of the GDL Editor (Master Window) explaining each graphic element.)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-11-29 09:03 PM
vistasp wrote:Vistasp, there is some documentation in Online Help, doing a search for GDL Master Window (a bit tricky).
Thank you, Karl and David. This information on macro templates is extremely interesting. It's not documented in the Reference Guide, is it?
In addition to Peter, Karl and David's excellent explanations, some info on parameter transfer (since AC9).
Object Editor > Parameters Window > Display > U button (fourth).
Unique toggle: if you switch this toggle on, this parameter will not accept parameter values from the default settings,
during a parameter transfer (CTRL-ALT-click [Win] / CMD-OPT-click [Mac]).
Interactive training guide, Creating GDL objects, chapter 6.
Unfortunately, this point is missing in the Online Help.
