2008-11-28 08:04 PM
2008-11-28 09:41 PM
2008-11-28 10:16 PM
2008-11-28 10:24 PM
2008-11-29 02:13 AM
2008-11-29 05:15 AM
Conrado wrote:'Template' lets you create your own named entries in the subtype hierarchy ... thus letting you choose your entry from the subtype hierarchy ("Select Subtype" button) which in turn would populate any new object based on your template with all of your template's parameters. This assures that a family of library parts will have all similar parameters identically specified...which simplifies work, guarantees that called 'family' macros will get parameters with the right names (no typos), and guarantees that the parts can be scheduled properly (all corresponding parameters guaranteed to have the same internal name).
Now that you clarify what the "Placeable"button is, can you explain what is the otherone"Template" for?
2008-11-29 02:35 PM
Karl wrote:In addition to Karl's list, it also assures that parameter transfer between similar library parts will work, for example, when injecting parameters from one window to another window inside the Window dialog box.
2008-11-29 04:45 PM
2008-11-29 08:23 PM
vistasp wrote:No, it's not. Neither in the GDL guide nor the Reference guide. It used to be there in older versions. Currently, the printed or PDF guide for 12 and 11 tells the user to refer to the online Help for "GDL Master Window". Personally, this business of not having a single, central document (Help or PDF) with
This information on macro templates is extremely interesting. It's not documented in the Reference Guide, is it?
2008-11-29 09:03 PM
vistasp wrote:Vistasp, there is some documentation in Online Help, doing a search for GDL Master Window (a bit tricky).
Thank you, Karl and David. This information on macro templates is extremely interesting. It's not documented in the Reference Guide, is it?
Great question, Conrado. I never even thought to ask.
