Achille Pavlidis
Manhole object?
Why there is no Manhole object in the MEP Library?
Mac OS 26.1 | AC 29.0.2 INT 3200 FULL
7 Replies 7
The ergonomic interface of archicad is to purify tools and functions. so I think it is possible to simply solve your request via a simple free bay (from a window or a door)
Does this match your search?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Achille Pavlidis
No, maybe I haven't used the correct word. What I'm searching for is a Water Interceptor. Its similar to a box placed in the earth where sewage or rain water pipes flow from different directions and then overflow to a main pipe.
Oups ok
I don't know why and I agree with you it's strange
So I've found this : https://www.bimandco.com/fr/objets-bim/4137-regard/details
Christophe - FRANCE
Achille Pavlidis
Yes! this is what I was looking for. Unfortunately IFC file type is not very handy
Erwin Edel
So basically a concrete box with round holes?
So a slab, 4 walls and 4 round opening windows?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Achille Pavlidis
...and a steel cover on top.
Yes
but parametric
Erwin Edel
If you make sure the slab edge and wall reference line touch, you can select the walls + slab and offset any edge as needed.
www.leloup.nl
