‎2009-01-11
12:45 PM
‎2023-05-26
11:28 AM
Rubia Torres
‎2009-01-11 03:13 PM
‎2009-01-11 05:14 PM
David wrote:Ok, but I do not understand why a specific material appears different on a
Fiuni:
You may need to use the Align 3D Texture command to change the direction of the texture [fill (hatch)] on the door.
David
‎2009-01-11 06:20 PM
‎2009-01-11 11:25 PM
Dwight wrote:Well, i can not understand that one material is appearing on two different ways, depending if you use it on a wall, or a door? If I choose a woodsiding that has a hatching (horizontal), why does it become vertical on the door.
But origins and orientations vary.
So, in this case, "up" is where the code says it is.
‎2009-01-11 11:34 PM
‎2009-01-11 11:41 PM
Dwight wrote:Ok, but I really can not understand that the wall and the door are coded different.. up is up..
Orientation is set with the object. My advice is to make materials with separate orientations to cope.
"Up" is where the code says it is.
‎2009-01-11 11:48 PM
‎2009-01-12 12:02 AM
‎2009-01-12 02:05 AM
Fiuni wrote:The wall is an element of Archicad and the hatching will behave as you expect it to (can be manually moved and rotated in 3D - "align textures").Dwight wrote:Ok, but I really can not understand that the wall and the door are coded different.. up is up..
Well.. anyway..thanks..
