KateS
Materials not working in a downloaded object
Hello!! I have downloaded this object from this page
https://www.archibaseplanet.com/download/c593c60f.html
but when i try to render it it has no materials. I don't know what's wrong..i tried to just drag and drop the file and i tried to add it in the library but nothing worked, it always gets rendered as blue, green and purple Anyone can help?I am opening the file in archicad 22. Thank you in advance
3 Replies 3
Guru
Does it show up in the 3D window with materials? Do the materials map to the files surface catalogue or inline definitions?
Ling.
KateS
Yes it does show up in the 3D window with materials!!
I don't really know how to answer the second question, i am new in using Archicad...
Guru
Can you go into the objects settings and change the materials? If so, you might want to check the materials CineRender settings.
Options => Element Attributes => Surfaces => CineRender by Maxon => [Surface Name]
Ling.
