2025-05-15 06:37 AM
We're experiencing an issue with doors and libraries not loading correctly in Archicad 27 after migrating a project from Archicad 26.
We've tried copying and pasting from the Archicad 26 file, migrating libraries, inserting objects, and reloading all relevant libraries correctly - but nothing has resolved the issue. Everything works fine in Archicad 26, but in Archicad 27 the doors and associated libraries will not load (I can copy into a new plain file).
Could this be a bug, or is there a known solution?
Solved! Go to Solution.
2025-05-16 01:22 AM
Deleting the 'Built in Library' worked! All missing doors and objects are back.
Thanks Barry!!! 😀
2025-05-16 02:04 AM
That is good to know.
I had run out of ideas otherwise.
