2004-03-25 06:07 PM
2004-04-03 04:00 PM
2004-04-03 04:18 PM
2004-04-04 04:56 AM
2004-04-04 01:02 PM
2004-04-04 04:19 PM
2004-04-04 09:40 PM
Millard wrote:probably because the detail tool itself was launched as a new feature - combined with the thorough organisation of objects into 'specialist' subtypes. it may have got lost as simply a 2D parametric object and found itself developed and classed into a subtype that can only be read by tools/objects that are able to access that sub-type?
I still have to wonder why this object was left out of the 8.1 library.
2004-04-05 05:39 PM
2004-04-05 08:28 PM
2004-04-06 12:41 AM
Matthew wrote:No good just renaming the part. Renaming plus changing the subtype worked. Thanks for all your help. I can now give up the 70 library!
Oh, of course, it makes sense now. With a part of the same name already loaded as a detail marker subtype ArchiCAD was ignoring the additional plain vanilla part. If you add the old part under a new name it should be visible in the library browser. (Assuming that this is what is happening)
