2020-07-31 11:15 AM
Solved! Go to Solution.
2020-08-03 11:18 AM
2020-07-31 11:37 AM
2020-08-03 03:33 AM
2020-08-03 09:18 AM
2020-08-03 09:19 AM
Braza wrote:I have read the toppic. It doesn't help me because even if I replace the missing files in Atribute Manager they are recreted when I reopen my .tpl/.pln file.
Have you checked this post?https://archicad-talk.graphisoft.com/viewtopic.php?t=48194
You can find more information in the Library Manager on the bottom part (Where the loading report appears).
Hope this helps.
2020-08-03 09:59 AM
Psyche wrote:
How cand I find those missing parts and replace/delete them for good?? And replacing them from atribut manager doesn't work because they are "recreated" when I reopen my .pln/ .tpl
2020-08-03 11:01 AM
2020-08-03 11:18 AM
2020-08-03 07:57 PM
2020-08-05 09:47 AM
Barry wrote:
I see they are in italic font in your attribute manager.
This means they are being automatically created by a MASTER_GDL object in one of your loaded libraries.
You will not be able to stop this unless you track down and delete that MASTER_GDL object.
Or find those texture files and add them to a loaded library.
