Missing Library Part or image -
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-07-31 11:15 AM
I'll start by saying that I use my own template (I created it starting from a basic templated with materials translated in my language and am editing it when necessary).
In the last few months I encountered a problem (from one version of my template to another). I have a list of missing Library Parts or Images.
Basically something is creating me about 80 new surfaces and fills and I cannot find how to solve the error. I've tried 'delete and replace' from attribute manager for both the surfaces and the fills and for the moment the error goes away. I save the .pln, save a new instance of .tpl but when I open the new .tpl the missing library parts appear again.
I tried to delete the embedded library and it does not solve the problem. If I save a .pla file i revise the message that there are some macros or library parts missing and the Report is showing me a long list of the same surfaces.
HELP!
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-03 11:18 AM
This means they are being automatically created by a MASTER_GDL object in one of your loaded libraries.
You will not be able to stop this unless you track down and delete that MASTER_GDL object.
Or find those texture files and add them to a loaded library.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-31 11:37 AM
You can find more information in the Library Manager on the bottom part (Where the loading report appears).
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-03 03:33 AM
Open the old version and go to the Library Manager to see what libraries are loaded.
You will need to load the same pones in your new template.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-03 09:18 AM
My problem is that I don't know how to find it and delete it. And I don't have any other new libraries imported since the las version of .tpl that didn't have this error. The only thing different is that I added a few .jpeg to the embedded library that I tripple checked for errors anf those are not it..
I tried to import all the libraries that I have on my computer and all I get are duplicates and the missin files are still there..
How cand I find those missing parts and replace/delete them for good?? And replacing them from atribut manager doesn't work because they are "recreated" when I reopen my .pln/ .tpl
Thank you,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-03 09:19 AM
Braza wrote:I have read the toppic. It doesn't help me because even if I replace the missing files in Atribute Manager they are recreted when I reopen my .tpl/.pln file.
Have you checked this post?https://archicad-talk.graphisoft.com/viewtopic.php?t=48194
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-03 09:59 AM
Open your Library manager and look at the warnings.
Choose one and click on 'More Information'.
It will probably say that the texture file is missing from a surface.
You need to edit that surface and either delete the texture completely or replace it with another.
If that is not it can you show a similar screen shot (as my attached) of your Library Manager showing the 'More Info' for one of the missing attributes.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-03 11:01 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-03 11:18 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-03 07:57 PM
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-05 09:47 AM
Thank you so much for the help given!
Barry wrote:
I see they are in italic font in your attribute manager.
