2024-11-14 08:53 PM
Operating system used: Mac Apple Silicon Sequoia 15.0.0
Solved! Go to Solution.
2024-11-17 04:00 AM
@KarlSchurz wrote:
My only issue is that the delete "X" is not an option when I highlight the file.
I don't have Archicad running on this machine, so I can't check if you can delete directly from the Library Manager.
I know you can if the objects are in the embedded library, but maybe not if they are in a loaded library.
However, you can delete them directly in the actual library folder in your operating system.
You will have to re-load the library in the Library Manager to check as you delete the files.
If you delete the correct files, the number of warnings will reduce.
But that is a lot of work, and is why I think it is best to remove that version 9 library completely and then replace the missing objects with something from a current library.
Or you can just ignore the duplicate warnings.
Especially if they are all image (.JPG) files.
