Missing Library Parts
ISSUE:
Showing the purple/black checkers for surfaces, missing parts showing as dots, etc.
Tried deleting and reloading the missing library parts
Checked other projects shows the same issue.
Opened up same project on different computer - shows library parts.
My presumption is that the computer not showing the library objects is the culprit. But how does it get resolved, even though I've removed, and added back, the missing library parts?
3 Replies 3
Nader Belal
Mentor
If you saw the second pic that you have just uploaded, you will find two things: [list=]
  • 1. You're loaded your library from teamwork.
    2. The size of the loaded library by team work is ZERO, nothing, nada.
  • So I think you should load your library.
    Had to reinstall, because the library was readded and still showing the missing library.
    Nader Belal
    Mentor
    Look I´m not versetail working over a network, and I think it's a problem with the configuration using ArchiCAD's Bim server
