2021-01-07 07:11 PM
Solved! Go to Solution.
2021-01-08 01:46 AM
2021-01-08 01:46 AM
2021-01-08 07:23 PM
Barry wrote:Thanks Barry for the prompt reply. I did not even realise that there was a 'Railing Tool'; I have only just started using AC 24. I had previously tried loading AC 20 Migration Library, but that didn't make any difference; I will try what you say.
The fence and railing objects no longer exist in the new versions (since version 21 I believe).
Loading the migration libraries (for all versions 20-24) should keep the old objects in your file.
We are expected to use the new railing tool now instead of these objects.
2021-01-09 03:08 PM
Dali_ wrote:That is because the MEP add-on is now part of the standard AC package (it was a separate add-on before), so those objects can be used as part of the MEP functions.
Interestingly, there is also a new 'Equipment Tool' – as I have just found out – that duplicates the kitchen equipment and cabinets that already exist in the Object Tool > Basic Library > Kitchen Cabinets, etc.
