sarahric
Missing Object from old library
With upgrading every year to a new ArchiCAD version, I have old migration libraries in my template which I am trying to get rid of.
In several projects where I remove the old library, I end up with missing objects. I go through all the layouts, stories, layers and renovation status' but still am left with at least 1 missing object.
How else can I search and find this object?
ArchiCAD 18/Windows 7/16GB Memory/i5 3.2GHz Processor/NVIDIA GeForce GT 610
14 Replies 14
sarahric
Sorry, what is SQL?
SQL=Structured Query Language
ArchiCAD projects are a special type of database and you can query it from inside archicad activating the SQL menu.
It's not the most easy tool to work with but i found it usefull in find things when search and select has failed.
sarahric
Thanks.
I could see how this would work.
davidstonearchicad21
Has the Query capability been removed from Archicad21 ?
Can't find it in the 'All commands alphabetical'
AC24
2 x Xeon E5-2667 v2 (16c/32t @ 3.3-4.0 GHz)
64Gb RAM(ECC) Quad channel 1333Ghz (next upgrade 1866Ghz)
Nvidia GeForce GTX 1080 Ti 11Gb
500Gb 840PRO SSD, 3 TB HDD (next upgrade PCIe NVMe SSD)
The last version to actually support SQL was version 18.
The command was removed completely in version 21.
https://archicad-talk.graphisoft.com/viewtopic.php?t=58300
