I have a custom wall type label object that is working just fine in our main models (new bldg & exist bldg), but when those models are hotlinked into our layout model, the object appears as a missing object. It is the only object that is not showing up. See attached image
Both models are using the same libraries, from the BIM Server. We are using ArchiCAD 14 #3477 (USA).
Any suggestions would be appreciated
Thanks,
