Missing library 12-11 parts
Hello
I have two questions.
Although I'm in a brand new (not striped out and carried forward) file, AC16 says I'm missing some libr 12 objects, but as you can see in attachment, they all have 11 in their names.
So, I'm searching my AC-12 disk but can't find a folder (lcf) or similar to load just the 12 libr for now. So where is the 12 libr on the disk??
AND
Why there an 11 in the object name?
Let me guess.....
Is it because it was in a migration libr that I've long since forgot about maybe?
3d
12 REPLIES 12
Eduardo Rolon
Eric,
Post apparently crossed. Mystery solved.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Thanks Eric and ejrolon
Loading migration lib 11,12 and 13= no change.
Loading migration lib 14 left only the ones showing in attached file.
Loading migration lib 15 Cleared the remaining 3 "missing" objects,
Hooray!!
Hindsight always being 20/20, I guess I should have tried to load the others on my own.
Update:
I unloaded migrations libraries 11, 12 and 13 just as a check and still have a clean library report,(no "missing objects").
Also took a look at AMT's hot linked files association and that's good.
The "missing" libr. objects did not cause problems, just wanted to chase it down while I was cleaning up some other missing parts I had made.
Thanks again everyone for the help, especially on a holiday!
