Mitred Sliding Door
vfrontiers
Does anyone know where I can find a sliding door that mitres at one end?
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
4 REPLIES 4
Normally this is where I say "Door and Window Builder can do this" but I have not found a way to have sliding doors meeting at a corner without a frame, if that is indeed what you mean by a mitre.
vfrontiers
Yup.. just tried DW Builder as well.
Duane
Visual Frontiers
Thomas Holm
Use an empty opening and a polygon wall for the mitred door.
vfrontiers
While this is a great modeling solution, I need to continue on with Construction Docs and need all schedule info to match the door. I have created a DUANE-EmptyOpening using the correct SUBTYPE. So I can achieve it that way.
Thanks!
Duane
Visual Frontiers
